-Stud Moving WIRE WHEEL HUB ---->Fixed!
Posted: Fri Aug 18, 2023 1:54 pm
by Professor Fate
What's the best way to repair a stud in a front hub for wire wheels that spins after you get it tightened down a bit? Any sneaky tricks???
Re: -Stud Moving WIRE WHEEL HUB
Posted: Fri Aug 18, 2023 2:02 pm
by speedytinc
They were originally swedged on the shoulder below the threads. Re-swedge the loose stud.
Same tool as model a hubs. I recall seeing a video of the job for model A's.
Posted: Fri Aug 18, 2023 2:55 pm
by Professor Fate
Do you have a pic of the tool?
Posted: Fri Aug 18, 2023 3:00 pm
by speedytinc
Go to langs. Put in wheel stud. First item up.
Posted: Fri Aug 18, 2023 5:52 pm
by Ed Fuller
Small tack weld on the back side.
Posted: Fri Aug 18, 2023 7:38 pm
by Allan
Re-swedging the stud may not be the answer. That process is meant to stop the stud moving in and out. Splines on the stud are supposed to stop it turning, and there is a flat on the head of the stud which engages on a low shoulder in the hub, as an additional stop. If your stud is turning in the hub, the splines are damaged and the shoulder gas been compromised. Time for the suggested weld, but it should be done with the stud under its usual tension, either in the car with the nut run up as usual, or off the car and still run up to tension.
Hope this helps.
Posted: Fri Aug 18, 2023 8:18 pm
by Professor Fate
I have plans to meet with a good friend Tuesday to make the repair.
Thanks for your thoughts. Much appreciated!
Posted: Sat Aug 19, 2023 9:30 pm
by Jack Putnam, in Ohio
There are no splines on thre model t replacement wheel studs.
Posted: Sun Aug 20, 2023 12:37 am
by speedytinc
duplicate, never mind.
Posted: Sun Aug 20, 2023 12:38 am
by speedytinc
What holds the stid is the swedge & the flat on the head that butts to a raised ring of casting.
A weld is an ugly patch. If the stud wont take a reswedge, replace it. They are readily available & cheap. MHO.
Posted: Sun Aug 20, 2023 3:57 am
by Professor Fate
Replacement is 1rst choice. Tuesday a.m.
I'll have the hub back on the car by suppertime.....
Posted: Wed Aug 23, 2023 8:56 am
by Professor Fate
Ed Fuller wrote: ↑Fri Aug 18, 2023 5:52 pm
I tried to re-swedge the stud.......
Unsuccesful. Had to resort to a tac weld with the stud compressed under tension.
There was another stud that had turned but was still locked in place. That one got a small glob of weld too.
Car is back together.
Thanks to all for teaching me some new T stuff. Much appreciated.
