Scandinavian Bands soaking or not?
Fozz71
First Name: Jim
Last Name: Chochole
MTFCA Number: 50481
Board Member Since: 2003
Post by Fozz71 » Fri May 17, 2019 9:39 pm
I haven't put Scandinavian bands in a T in almost 20 years but I am going to soon, do folks still find that pre-soaking them in oil is the best method?
Thanks,
Jim
Nv Bob
First Name: Bob
Last Name: Middleton
Re: Scandinavian Bands soaking or not?
Post by Nv Bob » Fri May 17, 2019 10:07 pm
Jim
I used to now put them in dry
Add a quart of oil over them after installed
Never had an issue in 20 sets doing it this way
Oh dint drain extra oil out yhe top pet cock
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Fri May 17, 2019 10:14 pm
I pre-soak for a couple days - everyone does what works for them.
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
MTFCA Number: 2406
MTFCI Number: 22213
Post by Jim, Sr. » Fri May 17, 2019 10:21 pm
Put the bands in and close up the cover. Start the engine and let it idle for a while. With all that oil splashing around they will be soaked up quickly.
1922 Coupe , 1926 Touring
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Fri May 17, 2019 10:36 pm
Agree!
Herm.
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Sat May 18, 2019 8:19 am
I soak them in automatic transmission fluid. I have changed one lining without soaking successfully, but next time I changed it the rivets didn't want to go in as they should. Change of material perhaps? I soaked it and no problem.
