high low bulb socket
Posted: Wed Aug 23, 2023 2:33 pm
by grizzledmike
does anyone know where I could get some headlight sockets high low the part where the bulb goes into
Re: high low bulb socket
Posted: Wed Aug 23, 2023 2:54 pm
by Tadpole
Do you mean these? Snyder’s should have them, part#T-6574-X
Posted: Wed Aug 23, 2023 4:46 pm
by Bill Robinson
Read this thread from a day or so ago. Lots of discussion about the headlight sockets and any vendors who has any in stock.
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=37785
Posted: Wed Aug 23, 2023 5:22 pm
by mike catlin
Maders model t parts had them in Wisconsin
Posted: Wed Aug 23, 2023 10:17 pm
grizzledmike wrote: ↑Wed Aug 23, 2023 2:33 pm
Are referring to the socket to fit bulbs with offset pins?
The normal setup was weither a BA15S (single contact) or BA15D for (Double Contact). Sockets for bulbs with offset pins are BAY15S or BAY15D.
Since BAY15 style bulbs are normally brighter & perhaps the source of the question. But I am unaware of Model T sockets with off set pins. Most users simple break off the high pin without issue. Other use LED bulbs. Trying to fit a BAY15 socket will require a tab to allow for adjusting the bulb to meet the focal point of the reflector
Posted: Thu Aug 24, 2023 5:23 am
by Arbs
A couple of weeks ago
double pin light sockets were out of stock at Langs, Snyders, MACs, and Smith & Jones. Chaffin's had them but they confirmed that they are struggling to order more. You may want to pick them up from Chaffin's while you can. Chaffins: (951) 226-7331
Availability across vendors may have changed since then.
Posted: Thu Aug 24, 2023 8:51 pm
by RVA23T
Might try here for sockets and led bulbs
www.ledlight.com/ba15d-socket.aspx
Posted: Thu Aug 24, 2023 11:21 pm
If you are looking for this, I have several new & used. email or PM me if you need them
