KC Warford ratios vs Muncie
Posted: Wed Sep 06, 2023 3:14 pm
by Dennis Prince
Howdy, I am trying to find out how the gear ratios of a Muncie and a KC Warford compare. I am looking for the ratio of the transmission not the final ratios at the rear diff. Any help would be greatly appreciated. Thanks Dennis
Re: KC Warford ratios vs Muncie
Posted: Wed Sep 06, 2023 7:00 pm
by Allan
Dennis, Layne, the makers of the KC Warford can help. There are different ratios for different applications. I have seen a chart illustrating these but cannot reference it.
Posted: Thu Sep 07, 2023 8:15 am
by Mark Nunn
Posted: Thu Sep 07, 2023 12:24 pm
by jsaylor
I have seen the KC Warford ad in the Vintage Ford showing the different ratios. For the Muncie, you can turn the input shaft and count the output revolutions to get the ratio.
Posted: Thu Sep 07, 2023 1:14 pm
by Craig Leach
This may help.
Aux-ratio.pdf
(8.23 KiB) Downloaded 88 times
The KC Warford add has their gear ratios
Posted: Fri Sep 08, 2023 8:13 pm
by Dennis Prince
Thank you all for the ratio info, it is what I was looking for.
