Inner tube discrepancy
Posted: Mon May 20, 2019 10:33 am
Over the weekend I was replacing an inner tube in a flat tire. I inflated the replacement 30x3-1/2 tube to make sure that all was well. Then I noticed the markings on the inner tube. This is the marking that is on one side:
This was on the other side of the inner tube:
It is definitely 30x3 tube.
If you have a spare tube that is put away you might want to open it up completely to make sure you have the right size!
