Moving brake lever
Millwork
First Name: David
Last Name: Bystry
MTFCA Number: 30209
Moving brake lever
Post by Millwork » Wed May 22, 2019 1:35 pm
I am going to build a cab for my ‘19 ton truck and was wondering if anyone knows a way to move the brake lever over to the left 6’’ or so? The truck also has an aux transmission and although l can create more leg room for my 6’4’’ body squeezing my legs between the brake lever and the trans shifter pretty tight. Any thoughts would be greatly appreciated.
Thank you
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Re: Moving brake lever
Post by CudaMan » Wed May 22, 2019 2:32 pm
MTFCA Number: 1219
Post by Rich Eagle » Wed May 22, 2019 2:33 pm
Here is how I did it on my speedster. You can lengthen the cross shaft or make a new one. The using tubing standoffs and carriage bolts mount the ratchet out farther. The lower bracket was fabricated.
Post by Allan » Thu May 23, 2019 8:18 am
David, if you are building your cab freestyle to no particular design, you have the opportunity to optimize your driving and seating position. Your 6' 4" frame can be well accommodated by shifting the seat assembly and backrest to the rear somewhat. If the cab is open, access is even better. My son's open cab 1/2 ton lorry poses no problems and the wide door and setback seat on my 17 shooting brake make entry easy. if you mock up your cab seating position first, you may find there is no need to shift the handbrake.
Hope this helps.
Millwork
First Name: David
Last Name: Bystry
MTFCA Number: 30209
Post by Millwork » Thu May 23, 2019 11:38 am
This is all great information guys and l really appreciate everyones input and like the saying goes a picture is worth a thousand words and yes l am definitely moving the seat back
Thanks again
Dave
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Thu May 23, 2019 12:02 pm
You can also move the lever back so you don’t have to reach so far forward to use it.
tom_strickling
Last Name: Strickling
Post by tom_strickling » Thu May 23, 2019 12:52 pm
Lever extensions are also available
TonyB
First Name: Tony
Last Name: Bowker
MTFCA Number: 32
Post by TonyB » Thu May 23, 2019 1:41 pm
I have put hand brake extensions on several height challenged customers cars, it really seems to help. I also have put an extension on the speedster as we moved the seats backwards, it works great.
Tony Bowker
Ramona, California
1909 Touring, 1914 Touring, 1915 Speedster, 1924 Coupe.
