Double Hassler Shocks
Posted: Wed Nov 01, 2023 1:59 pm
by GOLDBARBILL
When installing double soring hassler shocks, is it necessary to have/use two spring compressors? Bill Coupeville, WA
Re: Double Hassler Shocks
Posted: Wed Nov 01, 2023 3:15 pm
I did when I installed mine - think about it.
Posted: Wed Nov 01, 2023 3:19 pm
I would say positively YES. There are enough warnings regarding working on a single spring with a compressor. Also just one would not give even compression on the other.
Posted: Wed Nov 01, 2023 4:51 pm
by Afrazer
Most definitely yes. Just took a set off had to move one side down a little then the other spring and so on till I could take the brackets off the springs
