An oddity encountered while rewiring...
Posted: Mon Nov 06, 2023 7:18 pm
O.K. Progress is being made on this 1920 Touring's re-birthing, mostly concerning sorting out electrical issues that a previous owner blew off. A new or used horn switch seems to be the way to go to solve this past weekend's problem. See previous posting about that.
New problem encountered, although not a game killer. The wiring on this car was a rat's nest of old wires and needless add-ons. GONE!!! Back to basics. I have a couple wiring diagrams that agree with each other 95% of the time. I have been religiously following the connecting process for all three harnesses, real rocket science compared to rewiring a 1980 Corvette.
I have done this several times over the years, so I had no fear going in on this one. After completing the re-wiring, the engine starts right up. Previous to the new wiring, it was a maybe-yes, maybe-no proposition. A prayer got the coils buzzing every other attempt. Anyway, that problem has seemingly been resolved.
However, when the lights are turned on, the ammeter goes into the positive side. I know, I know. Switch the wires around back there. I did that and the needle now goes into the discharge side of the ammeter when the lights are turned on. Why was it necessary to do that? The wires are routed correctly per the diagrams, yet when the yellow wire with black tracer is connected to the positive ammeter terminal per diagram, the needle goes the wrong way. I probably should leave well enough alone, but I'd like to get this thing wired correctly without resorting to cludgey wiring sidesteps.
Any ideas why this opposite polarity issue exists in this car?
Marshall
Marshall
