Coil box amperage ?
Posted: Wed Nov 08, 2023 5:27 am
by Modeltmike
How many amps does a coil box draw. It is my understanding that a single coil should be set at 1.5 amps. Is it as simple as 1.5 x 4 = 6 amps?
Re: Coil box amperage ?
Posted: Wed Nov 08, 2023 6:23 am
by Jerry VanOoteghem
Modeltmike wrote: ↑Wed Nov 08, 2023 5:27 am
Only one coil is fires at a time, so only 1.5 amps.
Posted: Wed Nov 08, 2023 6:50 am
by Humblej
1.3 amps per coil if it is adjusted correctly.
Posted: Wed Nov 08, 2023 8:06 am
by Mark Nunn
Instructions for installing an E-Timer say to add a 4 amp fuse to the coil box. Total run amperage needs to be somewhere below that.
Posted: Wed Nov 08, 2023 8:17 am
by TXGOAT2
Only one coil at a time is in operation, and for some of the time during engine operation, no coil is operating. Average coil current during coil operation is in the 1.2 to 1.5 amp range. A 4 amp fuse would be correct, if a fuse is present. Coils behave differently when operating on battery current (6 volts DC) as opposed to magneto (Alternating current, about 5 volts AC to about 30 volts AC) Two coils will fire during each revolution of the engine.
Posted: Wed Nov 08, 2023 9:21 am
by Been Here Before
To add to the discussion, and of course be criticized, if you observe your ampere meter, set the ignition switch to battery, and turn your motor by hand crank, with the coil buzzing, you should observe that the meter will show a discharge of about 2 amps, or one line to the left (a discharge). Of course if you use a buzz box with a three ampere meter, you will note a current draw of 1.5 to 2 amperes.
- DSCN1618a.jpg (48.01 KiB) Viewed 1877 times
Posted: Wed Nov 08, 2023 4:03 pm
by JohnH
The Ford ammeter installed in the dash is far from a precision instrument, and is certainly not accurate enough to set coil current using the buzz box method. It's just a rough guide that everything is working properly.
The 4A fuse specified for the E-Timer is to protect the E-Timer itself, in case a coil is completely short circuited.
