Storing inner tubes
Posted: Fri Nov 10, 2023 2:07 pm
by South Park Zephyr
I was wondering if there is a proper way to store new inner tubes that will keep the viable?
At this time they are folded and secured with a rubber band.
Thanks,
Scott
Re: Storing inner tubes
Posted: Fri Nov 10, 2023 2:14 pm
I put them in a zip-lock bag with baby powder. Remove as much air as possible.
Even older salvaged tubes keep for decades.
Leave a similar new or old tube to the air, it will crack @ the seems & folds in a few months.
Posted: Fri Nov 10, 2023 2:21 pm
I store mine in the shop, in the dark, aired up a bit.
Posted: Fri Nov 10, 2023 3:11 pm
by George House
I’m in the zip lock bag w/baby powder crowd. But I Don’t store them in my shop. I leave them in the closet of one of the guest bedrooms. My uninsulated shop has been 120* in the summer. That’ll make them crack.
Posted: Fri Nov 10, 2023 3:16 pm
by Dan McEachern
Folded or rolled, they seem to crack along the unadvoidable flat edge, at least mine have. Probably best is lightly inflated with nitrogen and in a dark cool place, but....
Posted: Fri Nov 10, 2023 4:01 pm
by TWrenn
Dan McEachern wrote: ↑Fri Nov 10, 2023 3:16 pm
I don't do nitrogen but do believe just enough air to inflate, store in basement. Seems to be no different then than inside a tire with varying temperature swings wouldn't it? Keeping them folded I think is definitely not a good idea.
Posted: Fri Nov 10, 2023 5:07 pm
by Russ T Fender
I keep them partially inflated in old tire casings in my basement where the temperature is fairly stable.
Posted: Mon Nov 13, 2023 9:24 pm
by NHUSA
I put the tubes in the old tires, slightly inflated them, and wrapped them in stretch wrap.
Posted: Mon Nov 13, 2023 10:08 pm
by Cordes_jeff
I fold them and put them in used plastic grocery bags. I double bag them and put them in a cabinet. I've stored them for decades like this.
Posted: Mon Nov 13, 2023 11:53 pm
by Craig Leach
Air conditioning only in the original package in the house house. I find a reliable local supplier & try not to store them
any longer than I have to. Used I store aired up inside the house also. ( do have 21" on my Ts so I can get tires & tubes
from the model A suppliers also.)
Craig.
Posted: Tue Nov 14, 2023 2:55 am
It does depend a bit on the tubes themselves. I store my old Olympics, folded and stowed in a carton, in my cellar which is at a constant 72 degrees.
Modern tubes don't do a very good job of holding air, so it is a moot point trying to store them anyway.
Allan from down under .
Posted: Tue Nov 14, 2023 8:38 am
Thank you to everyone.
It is good to hear the different ways that have been successful.
Scott
