ruckstell adjustment
Posted: Fri Nov 10, 2023 9:58 pm
by mike37 cdn
hi all I am working on a 22 centerdoor with a Ruckstell rear end I had a leak were the shift lever housing bolts on it has two 7/16 fine thread bolts on one side of the housing and one on other side is a 7/16 bolt and a 9/16's head with a lock nut below it and a point on it it to go into something inside any body know what the adjustment should be for this bolt thanks mike
Re: ruckstell adjustment
Posted: Fri Nov 10, 2023 10:23 pm
That bolt tightens down into the notch plate - one of two - snug it up good then tighten the jam nut.
Posted: Mon Nov 20, 2023 12:17 pm
by Craig Leach
Hi Mike,
I found that the gasket did not mate the flange completely. I had to remove the shifter & make a gasket that fit better.
Craig.
