Camshaft flange detail
Posted: Mon Nov 13, 2023 8:46 am
by Rajo T Speedster
Does anyone know if the flange near the front of a T cam is part of the cam machining or is it shrunk on?
Still trying to find a suitable cam for a Rajo OHV head engine.
John
Rajo T Speedster
Western Australia
Re: Camshaft flange detail
Posted: Mon Nov 13, 2023 10:28 am
by OlGeezer
I'm no expert, but from my experience, the flange near the front of a T cam is usually machined as part of the camshaft. I haven't heard of it being shrunk on separately.
Posted: Mon Nov 13, 2023 11:49 am
by Jerry VanOoteghem
I am certain that the flange is integral to the shaft and not an add-on piece.
Posted: Mon Nov 13, 2023 12:49 pm
by Craig Leach
Hi John,
If my memory serves me correctly the Rajo rocker arms are a1:2 ratio this will give you almost a 1/2" lift with a stock cam. If valve timing
is what you are looking to change I think Dan McEachern makes a timing gear set for that reason.
Posted: Mon Nov 13, 2023 1:06 pm
by RajoRacer
I installed a Chaffin's "modified" reground camshaft in my BB RAJO near 30 years ago now - it performs quite well !
Posted: Mon Nov 13, 2023 1:47 pm
by Dan McEachern
Many commercial Rajo heads used 1:1 rocker arms, so be aware.
Posted: Mon Nov 13, 2023 1:55 pm
by kmatt2
John, If you are going to run a reground Model T cam you will need to use a late 1924-27 T cam , the cam with the long front lobe. The earlier T cams use a shorter front lobe and a longer front bearing to take up thrust , but require modified front thrust when regrinding because the long front bearing won’t limit thrust on reground cam due to the cut down cam heal .
Posted: Tue Nov 14, 2023 1:52 am
by Craig Leach
Hi Dan,
That is what I love about the Forum I get to learn something new every day.
John,
Kevin is correct about the early year regrind cams but if you have a Bosch timing cover distributer there is a thrust
adjusting screw in the cover for that. & the thrust washer kit is not expensive or hard to install most of the time.
