magnaflux
- First Name: Les
- Last Name: Schubert
Re: magnaflux
I’ve never bothered, as the cracks are generally visible to the naked eye. Bottom of the water jacket, especially behind the water inlet. Also look inside the valve chamber. And then look between the valve seats and the cylinder bores. After hot tanking the cracks are usually quite obvious.
Crankshafts I Always get magnafluxed I usually measure first, and if they won’t clean up at bigger than.020” undersize I set them aside!!
- Last Name: Gulbankian
Topic author - Posts: 239
- First Name: Philip
- Last Name: Thompson
Re: magnaflux
thanks guys a chapter member has a block he is willing to give me for my car he just wants the cost of the magnaflux back 100.00
seems like a nice round number. philip
Re: magnaflux
Philip, the charge often includes two processes. To do the job well requires the block to be thoroughly cleaned first. This may mean hot tanking the block prior to the crack test.
- Last Name: Hughes
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
- MTFCA Number: 216
- MTFCI Number: 23070
Re: magnaflux
I just had a block done. Wasn’t hot tanked. It is baked at a high temperature then blasted with a fine steel shot. Then magnafluxed. It cost me $100.
