magnaflux
Posted: Thu May 23, 2019 2:29 pm
by Philip
has anyone had a block magna fluxed. lately if so what did it cost. philip
Re: magnaflux
Posted: Thu May 23, 2019 2:48 pm
by Les Schubert
I’ve never bothered, as the cracks are generally visible to the naked eye. Bottom of the water jacket, especially behind the water inlet. Also look inside the valve chamber. And then look between the valve seats and the cylinder bores. After hot tanking the cracks are usually quite obvious.
Crankshafts I Always get magnafluxed I usually measure first, and if they won’t clean up at bigger than.020” undersize I set them aside!!
Re: magnaflux
Posted: Thu May 23, 2019 3:03 pm
by J and M Machine
philip wrote: ↑Thu May 23, 2019 2:29 pm
We typically charge $80.00 . In order for the magnaflux to work properly the block has to be perfectly clean,no paint,oil or dirt.
Re: magnaflux
Posted: Thu May 23, 2019 4:13 pm
by Philip
thanks guys a chapter member has a block he is willing to give me for my car he just wants the cost of the magnaflux back 100.00
seems like a nice round number. philip
Re: magnaflux
Posted: Thu May 23, 2019 8:45 pm
Philip, the charge often includes two processes. To do the job well requires the block to be thoroughly cleaned first. This may mean hot tanking the block prior to the crack test.
Re: magnaflux
Posted: Thu May 23, 2019 11:29 pm
by Steve Hughes
I just had a block done. Wasn’t hot tanked. It is baked at a high temperature then blasted with a fine steel shot. Then magnafluxed. It cost me $100.
