running board iron support adjustments
Posted: Mon Dec 04, 2023 1:42 am
by popeyet
I am rebuilding a 1915 T runabout. I have acquired a very nice frame but am having to install the supports for the running boards. The will each need some adjustments as they are used parts out of a pile of parts. I looked up earlier discussions and found some that are over ten years old. There is reference to factory drawings that detail the specs on where the supports should be to correctly align the running boards so the fenders and apron will fit correctly.
Can anyone help me with this? there was a link to a page with a PDF file but it seems to have gone away on the internet.
Thanks.
Re: running board iron support adjustments
Posted: Mon Dec 04, 2023 3:35 am
by williamcournoyer
popeyet wrote: ↑Mon Dec 04, 2023 1:42 am
smash karts to install the supports for the running boards. The will each need some adjustments as they are used parts out of a pile of parts. I looked up earlier discussions and found some that are over ten years old. There is reference to factory drawings that detail the specs on where the supports should be to correctly align the running boards so the fenders and apron will fit correctly.
Thanks.
I think you can find something useful here:
https://modeltfordfix.com/the-1915-model-t-ford-part-1/
Posted: Mon Dec 04, 2023 7:50 am
by DanTreace
Posted: Mon Dec 04, 2023 8:36 am
by schwabd1
Google "running board bracket jig, mtfca". It's a post on a jig Tom Rootlieb made to get your brackets perfect. There's a link with all the measurements to make your own.
Posted: Mon Dec 04, 2023 8:51 am
by DanTreace
schwabd1 wrote: ↑Mon Dec 04, 2023 8:36 am
Link to that post:
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=38189
Posted: Mon Dec 04, 2023 11:08 am
by popeyet
Thank you guys, this is great!
Chris.
Posted: Tue Dec 05, 2023 7:13 am
by schwabd1
