Accessory shock ?
Posted: Tue Dec 05, 2023 5:09 pm
by tom_strickling
Ever see one of these before??
Re: Accessory shock ?
Posted: Tue Dec 05, 2023 6:21 pm
by ThreePedalTapDancer
Yes it’s an accessory single shock absorber. Interesting and desirable. I’ve seen one other in my travels.
Posted: Tue Dec 05, 2023 7:29 pm
by Moxie26
Too bad the main leaf is in pieces
Posted: Tue Dec 05, 2023 7:47 pm
by TXGOAT2
Road salt.
Posted: Wed Dec 06, 2023 7:36 am
by warwick_preval
Hello All, can someone tell me what type of brake drum or drums that is in this photo cheers Warwick.
Posted: Wed Dec 06, 2023 10:09 pm
by tom_strickling
Looks like drums added overtop of the Ford drum for accessory brakes such as Rocky Mountains. The car had small brake drums, but the accessory drum is larger.
Posted: Thu Dec 07, 2023 6:54 am
by warwick_preval
THANKS Tom cheers Warwick.
Posted: Thu Dec 07, 2023 12:42 pm
by John Codman
I would remove that accessory shock absorber before I ever drove that car (from what I see my guess is that is a ways off). It is putting loads on parts that were not designed to take them.
Posted: Sat Dec 09, 2023 10:10 am
The shock uses heavy cast formed brackets on the top and rear end. You can adjust the tension to get desired spring action. I’ve seen a brass case one before. Since I like weird accessories, I’d run it myself just to confuse and baffle other T owners. I’d reduce the spring tension if any concerns about design.
