Bosch type 448 distributor set up
Posted: Sat Dec 09, 2023 1:27 pm
by Fisher400
Hello,
I have a 26 engine that has an original Bosch front plate 448 distributor. The car has always been very hard to start and I am trying to verify the basics. Could someone confirm install instructions on an original Bosch 448? I currently have TDC identified, points are open but the rotor is pointing to the passenger side fender. I read the rotor should point to the #1 cylinder. Also, this distributor has a thumb screw on the opposite side of the coil wire. Is this intended to have a ground wire or strap attached?
Thanks!
Re: Bosch type 448 distributor set up
Posted: Sat Dec 09, 2023 2:02 pm
Think the pages may b in reverse order
Posted: Sat Dec 09, 2023 2:09 pm
by Fisher400
That’s great, thanks for the doc!
Posted: Sat Dec 09, 2023 3:31 pm
by Fisher400
Instructions were great, set up as described and added the ground wire as instructed. It did start, but I am having a rpm surging at idle. I am running a Winfield sr downdraft. Any thoughts on the source of this? Intake gasket and carb gasket have been replaced…
Posted: Sat Dec 09, 2023 5:43 pm
Instructions in the PDF first page below
2104WinfieldSR.pdf
(374.83 KiB) Downloaded 47 times
Think this Winfield
