Swedish snowplow
Posted: Sat Jan 06, 2024 11:08 am
by Rich P. Bingham
An impressive arrangement. Though it's chained up, I question whether the model T has enough traction for those plows if the snow were very deep ?
Re: Swedish snowplow
Posted: Sat Jan 06, 2024 12:02 pm
by Art M
Last summer someone posted a similar staging.
Art Mirtes
Posted: Sat Jan 06, 2024 12:12 pm
by Les Schubert
Pile a bunch of the neighbors into the back seat!!
Posted: Sat Jan 06, 2024 12:21 pm
by George House
In inclement weather I’m glad the top is down, side curtains neatly folded under the rear seat and the gentlemen wear appropriate ties
Posted: Sat Jan 06, 2024 6:04 pm
by tdump
That aint a T rear end in that car,so it may have a stronger drive train. I don't see a lift mechanism.
Posted: Sat Jan 06, 2024 8:09 pm
by havnfun
Mack, the wheels look like after markert wire, something like buffalo’s , large hubcap, the hubcap can also be seen on front wheel…
Posted: Sat Jan 06, 2024 9:17 pm
by Rich P. Bingham
tdump wrote: ↑Sat Jan 06, 2024 6:04 pm
you can see the rear end ??? I sure can't. No need to lift that plow. You can see its working clearance.
Posted: Sat Jan 06, 2024 10:48 pm
by tdump
Rich P. Bingham wrote: ↑Sat Jan 06, 2024 9:17 pm
you can see the rear end ??? I sure can't. No need to lift that plow. You can see it's working clearance.
i am judging by the size of the hubs, they are sticking out further from the wheel than standard are they not,and appear to be larger diameter.
Posted: Sat Jan 06, 2024 10:54 pm
by tdump
Here is a bigger pic of the hub,that just looks to be bigger than standard,wire wheel yes,
Posted: Sat Jan 06, 2024 11:13 pm
by havnfun
Mack,
Model T Buffalo wheel
