EZ cold start jack
RalphS in NE Oregon
First Name: Ralph
Last Name: Swinehart
* REQUIRED* Type and Year of Model Ts owned: 1914 roadster, 1914 touring, 1923 roadster, 1926 TT
MTFCA Number: 1386
MTFCI Number: 20289
EZ cold start jack
Post by RalphS in NE Oregon » Mon May 27, 2019 7:03 pm
I started my 14 for the first time this year yesterday, and since it was cool I couldn't get it started normally so I resorted to jacking up a rear wheel and got it started OK. It's a pain having to jack it up so today I decided to try to build a simple axle lifter to do the job easier. This is what I came up with.
I made a notch in a 4x4 by boring a hole thru it with a 2 1/2" hole saw then cutting thru the hole leaving a half round notch. Then I nailed it together on a 48" 2x4 and added a couple of plywood gussets. You just set the notch under the axle (it will be at a slight angle) and push down on the long bar. The car needs to be in neutral as it will rock a few inches as you lift. It lifts the rear wheel about 1/2" off the ground, and seems to be quite stable.
Ralph
Matt in California
First Name: Matt
Last Name: G
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
MTFCA Number: 30697
Re: EZ cold start jack
Post by Matt in California » Mon May 27, 2019 7:08 pm
Nice job Ralph!
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Mon May 27, 2019 8:08 pm
All those old time T owners would approve :D
baltrusch
First Name: Kurt
Last Name: Baltrusch
* REQUIRED* Type and Year of Model Ts owned: 1914 speedster, 1918 Touring, 1922 Sedan
Post by baltrusch » Mon May 27, 2019 9:03 pm
I found this jack some time ago and painted it and put on a new handle. I works well but you'd have to have a pickup to take it along! It was made by J.H. Whetstone in Michigan.
doodlebugt
First Name: Bruce
Last Name: Csorba
* REQUIRED* Type and Year of Model Ts owned: 1915 4 spring Rajo racer, 1917 C-cab van, 1925 Dalgety tourer
Post by doodlebugt » Tue May 28, 2019 1:08 am
Great Barn thinking, love it.
I'd consider a hose clamp or (being for a T) a couple of laps of baling /fencing wire just below the notch to mitigate against splitting.
Bruce
Bruce Csorba
Melbourne, Australia
15 4-spring Rajo racer
17 C-cab van
25 "Dalgety" Tourer
Jeff5015
First Name: Jeff
Last Name: Schroeder
MTFCA Number: 50300
MTFCI Number: 87
Post by Jeff5015 » Tue May 28, 2019 7:13 pm
Sorry if i'm not up to speed on this...
How/why does lifting a rear wheel make it easier to start?
Jeff
1916 Touring
RalphS in NE Oregon
First Name: Ralph
MTFCA Number: 1386
MTFCI Number: 20289
Post by RalphS in NE Oregon » Tue May 28, 2019 10:37 pm
Even with the car in neutral, there can be a lot of drag in the 25 clutch discs due to the oil between them still trying to hold them together some. And you can have a little drag in your bands. You have to overcome all this when you are cranking with the wheel on the ground. With one wheel in the air the drag actually works to your advantage by letting the wheel spin and act as a flywheel. Gives you a little more time to get to the spark and throttle after you have cranked her up. It's surprising how fast the rear wheel spins, but it stops easily when you apply the parking brake. Good idea to have a block in front of a front wheel just in case.
Ralph
NHUSA
First Name: Fred
Last Name: Dimock
* REQUIRED* Type and Year of Model Ts owned: 1919 T with Mifflinburg Suburban body
Post by NHUSA » Thu May 30, 2019 12:10 pm
I don't need no wheel block!
I use the Model A front bumper when the T is in the garage.
NH - Where I used to live - not the carburetor ! :lol:
Last Name: House
MTFCA Number: 115
Post by George House » Thu May 30, 2019 2:19 pm
That’s fine and dandy when you’re at home and in the garage but what about a lunch or ice cream stop on a club tour ? With my ‘14 runabout I carry a bottle jack with a pipe extension welded to a steel cradle that cups under a rear axle + a six inch 4x4 to place in front of a front wheel. The steel “cradle” acts like the upward curls of a jack stand. I keep em in the turtledeck but they’ll fit easily in a runningboard tool box.
RalphS in NE Oregon
First Name: Ralph
MTFCA Number: 1386
MTFCI Number: 20289
Post by RalphS in NE Oregon » Thu May 30, 2019 4:43 pm
George,
I don't plan to carry it with me since the car starts fine with the crank when it is not cold.
I have been playing with it more and it can raise the axle with only a 2' long 2x4 arm. This could be a cheap and easy way to take the load off your tires when the car is stored for the winter.
Ralph
