shocks
Posted: Mon Jan 22, 2024 2:53 pm
by Philip
looking for information on putting modern shocks on a model t. what shocks and how to mount.philip
Re: shocks
Posted: Mon Jan 22, 2024 3:15 pm
by Philip
there was a thread on the subject but i have no luck searching anymore
Re: shocks
Posted: Mon Jan 22, 2024 3:31 pm
by CudaMan
Re: shocks
Posted: Mon Jan 22, 2024 3:43 pm
by Philip
thanks mark i found that one there is one somewhere that shows the fronts
Re: shocks
Posted: Mon Jan 22, 2024 6:18 pm
by MichaelPawelek
Phillip, In the past on a Touring and a Coupe I found the ride greatly smoothed out by refurbishing and lubricating both front and rear springs. A stiff ride is generally an indication of worn and non lubricated spring set up. The Model T rides quite comfortably when the springs are in good shape…
Re: shocks
Posted: Mon Jan 22, 2024 7:25 pm
by Rich P. Bingham
Another aspect of "ride" is tires. Recently changed out old rock-hard tires for new, fresh, pliable tires and the difference was remarkable!
Re: shocks
Posted: Mon Jan 22, 2024 11:12 pm
by Bill Mullins
My method is using 1965 & earlier VW shocks front & rear.They work very well as Tom says the rear make the big difference.
Re: shocks
Posted: Mon Jan 22, 2024 11:15 pm
by Bill Mullins
Re: shocks
Posted: Tue Jan 23, 2024 12:40 pm
by 1925 Touring
Its not your fault, its googles fault. It wont show mtfca search results anymore.
If you switch to a different search engine you may have more luck with a search.
Re: shocks
Posted: Tue Jan 23, 2024 2:13 pm
by Philip
bill can you give me a picture of the mounts?
Re: shocks
Posted: Tue Jan 23, 2024 10:04 pm
by SurfCityGene
Philip, The ones I have seen on the NW Montana 500 racers where smaller VW type and attached directly to the differential tube. They were Much less offensive looking than some others but not Model T era for sure. If you can find a picture of Tom's I would copy his idea and could easily be home built.
