Old brass Zenith Carbureator
Posted: Wed Jan 24, 2024 10:04 pm
by Dennis_Brown
This Zenith Carb is Patented Dec 29, 1908. I have never taken it apart but it sounds like it has a brass float in it. On the side is cast 04 and to the right of that i stamped F5988 and a 0 laying sideways. The throttle plat is not the normal tin plate but a tapered brass disc that is a little over 9/64 thick.
It looks like there may have been an air filter that went on it. Below the choke there is a band with a slotted and knurled headed machine bolt with a nut. This band can be turned to open or close a slot on either side that is slightly less than 1/2 inch high and about 1 inch long. the thread at the throttle is just under 1 11/64. The bolt holes are 5/16 NC. There is very minimal wear in the throttle and Choke shaft. the choke has a very strong spring under the lever.
Anyone have an Idea what it may have been used on as it is an updraft or know anyone looking for one. Like a lot of other things it has been in my attic for at least 30 years.
Re: Old brass Zenith Carbureator
Posted: Thu Jan 25, 2024 1:55 am
by KWTownsend
There were available aftermarket for Model T. They came with a special manifold, too.
They may have been used on Che^rolet in the teens.
Posted: Thu Jan 25, 2024 10:16 am
by Craig Leach
Special manifold for 04 Zenith carberator
Posted: Thu Jan 25, 2024 10:59 am
by TRDxB2
Since its an updraft carb the "special" part of the manifold was to clear the generator.
The 04 was original equipment on some Chevy & Essex models.
This manifold made many years ago with a boss to accommodate Model T linkage. There are also original (aftermaket?) manifolds like it without it.
Helpful documentation
Rebuild Intructions.pdf
(5.01 MiB) Downloaded 55 times
YTest-adjust instructions.pdf
(2.45 MiB) Downloaded 58 times
04 Brochure https://www.mtfca.com/discus/messages/3 ... 1373409689
