Loose threads
Posted: Sun Jan 28, 2024 4:28 pm
by Will
Has anyone ever used aluminum foil around the sparkplug to tighten loose threads in an aluminum head. I think one of the plug hole threads in my aluminum high comp head are getting worn. I don't like the way it feels when I tighten the plug.
Re: Loose threads
Posted: Sun Jan 28, 2024 4:31 pm
Is it a 14mm thread, or 1/2" pipe thread?
Re: Loose threads
Posted: Sun Jan 28, 2024 4:34 pm
by Will
The plugs are 1/2 NPT
Re: Loose threads
Posted: Sun Jan 28, 2024 4:52 pm
The problem is easily solved by using adapters for modern plugs. Screw the adapter in once only, with the sealant of your choice, and then use modern plugs. You may not like the look though.
Re: Loose threads
Posted: Sun Jan 28, 2024 4:56 pm
by Les Schubert
1/2” npt Helicoil is available. I have the kit and have probably fixed at least a dozen over the years!
Re: Loose threads
Posted: Sun Jan 28, 2024 4:58 pm
When putting plugs in an aluminum head, Anti seize compound should be used to protect the head threads from galling.
Try some & see if the plug doesn't go in to far before tight. If you are not familiar with it, its basically aluminum powder & oil made into a paste.
Plug adapters are an option. I still put anti seize on the adapters.
Re: Loose threads
Posted: Mon Jan 29, 2024 2:07 am
by Craig Leach
Hi Will,
If you don't like the looks of the modern plugs & adapters they can be made from the later crimp style 1/2" npt plugs so they look like 1/2"
- plug adapter.jpg (11.15 KiB) Viewed 1614 times
plugs
- plug adapter1.jpg (9.4 KiB) Viewed 1614 times
Craig.
Re: Loose threads
Posted: Mon Jan 29, 2024 8:02 am
by Will
Thank you everyone.
Re: Loose threads
Posted: Mon Jan 29, 2024 10:49 am
I have used aluminum foil in a steel head. The threads had gotten rusty and when I tightened the plugs some of the compression would cause oil bubbles to come up around the plugs. The aluminum foil seemed to seal them just fine.
