Restoring a KR Wilson transmission fixture
Posted: Tue Jan 30, 2024 2:15 pm
Last year I purchased a KR Wilson transmission fixture complete with reamers. Upon inspection I saw the hole in the fixture was badly worn and the reamers needed sharpening. I sent the reamers out and made a sleeve to insert in the bored hole of the fixture.
I don't have a Bridgeport or an auto feed so everything was done manually in my mill drill and import lathe.
I purchesed a quality carbide boring bar with inserts and a better boring head. I had a couple of 12L14 steel rods I turned down to center first the fixture for boring and then the sleeve in the fixture.
Here are some photos
This is the first alignment rod turned to fit the existing hole with a close slip fit. Purpose was to center the fixture to the quill. Surprisingly no shims were needed between the bed and fixture. These two photos show the hole bring bored to accomodate a 660 bronze sleeve with a wall thickess of 1/8 " and enough clearance for sleeve retainer. The sleeve was bored on my lathe to .00075" to .0015" clearance to the reamer shanks which varied abuot 1 thou in diameter. The first photo shows the sleeve inserted on the second alignment rod turned to fit the sleeve within 1 thou clearance. The bottom of the sleeve is knurled to prevent the sleeve from falling off the bar. Both the top and bottom edges are taped to the bar to prevent sleeve retainer from seeping in.
The last photo shows the sleeve and alignment rod lowered into the fixture with the quill after applying sleeve retainer. It was important that the fixture was not moved once the boring was complete so the sleeve would be centered in the bored hole.
More to follow.
More to follow.
