26 coupe original sun visor question
Posted: Fri Feb 16, 2024 1:57 pm
by Jmeredith
What is the small hole in the visor side piece for?
On any of the pictures that I have seen on the forum this hole is not present. It’s on both side pieces.
Also does anyone have a photo of how the flat metal piece is placed on the cover and the tabs bent back over to hold the cover on. Not sure what it’s supposed to look like when finished.
Re: 26 coupe original sun visor question
Posted: Fri Feb 16, 2024 2:04 pm
by Jerry VanOoteghem
Jesse,
The flat metal piece looks exactly as you show it, except the covering goes under it. The two fold-over tabs go through two slits the cover material, the metal plate slips over the tabs, and the tabs are bent down as you've shown them. In other words, it's visible when everything is done so, be sure to paint it nicely.
The small holes you refer to do not belong there.
Be sure the strip along the leading edge of the frame has not been too weakened by rust. It's common that they are... Now is the time to reinforce it, if need be. Otherwise, a good gust of wind can break it and ruin your day.
Posted: Fri Feb 16, 2024 6:58 pm
by varmint
I have some pictures but they are not mine and I don't remember where they came from.
Posted: Fri Feb 16, 2024 9:37 pm
by Jmeredith
So that makes sense to me. The ribs are not encased with the fabric. Thanks
Posted: Sat Feb 17, 2024 5:57 pm
Jmeredith wrote: ↑Fri Feb 16, 2024 9:37 pm
YES, they are. What's shown above is not correct.
Posted: Sat Feb 17, 2024 6:35 pm
by Jmeredith
Thanks Jerry, so the leatherette is placed around the frame and then tucked up inside and sewn. Then screwed into the wooden header. I guess some kind of glue or such is used to attach the side pieces to keep them from puckering after the metal pieces are installed.
Thanks for the pictures. They really help.
Posted: Sat Feb 17, 2024 6:46 pm
Jmeredith wrote: ↑Sat Feb 17, 2024 6:35 pm
Jesse,
There is no glue used in my visor. The covering slips snuggly over the frame and is stitched shut across the back edge.
Posted: Sun Feb 18, 2024 9:00 am
by jiminbartow
I bought my all original (except for the red paint), never restored 1926 Fordor in 2004 that I sold in 2022, but I still have a lot of pictures. It had the original factory installed roof and sunvisor, although the sunvisor was missing those brackets under each edge. I attribute it to the factory workers at that station who may have been pressured by the speed of the line, may have been short on time and chose not to install them. Unlike in your picture, the material was slid onto the frame like a pillow case with material on the top and bottom totally enclosing the frame and stitched around the inside of each opening of the frame to bring the two halves together and make it tight. Jim Patrick
Posted: Sun Feb 18, 2024 11:15 am
by Jmeredith
That’s interesting I wonder if the fordor was done differently?
