Coi Tar
Posted: Fri Feb 23, 2024 5:11 pm
by Plankhill
Where are you coil fixers getting your tar from these days?
Re: Coi Tar
Posted: Fri Feb 23, 2024 5:21 pm
by mtntee20
Drop by any commercial roofing job with a dozen donuts and talk to the guy working the tar pot. I'm sure he'd give you a couple of big pieces of tar. :lol:
Re: Coil Tar
Posted: Fri Feb 23, 2024 5:29 pm
by Charlie B in N.J.
Now I,m not in the coil business but I’ve done about 20 over the years. I’ve never needed to buy tar. I do my removal of the old cap over a few sheets of newsprint or a large piece of cardboard and I capture all that comes out. I remove the side of the case where the cap sits first. Never broke one yet. It makes the tar and cap removal as easy as it can be. I make up the empty space created in the cavity by the much smaller replacement part by using wood bits. I usually leave the glass insulator in place. :twisted: Works very well. I bend a spout in a small can and clip on a pair of vice grips as a handle. A propane torch, used outside of course, provides the heat to melt the tar.
Re: Coi Tar
Posted: Fri Feb 23, 2024 5:31 pm
Roofing contractors that do flat roofs, commercial bldgs, or in lumber yards usually have pieces of roofing tar laying around where it’s been stored and moved around.
Re: Coi Tar
Posted: Fri Feb 23, 2024 6:07 pm
by Ron Patterson
When you contact roofing contractors looking for coil rebuilding tar specifically ask for Type III Steep roofing asphalt.
Ron Patterson
Re: Coi Tar
Posted: Fri Feb 23, 2024 6:14 pm
by Ron Patterson
Here is a photo.
Re: Coi Tar
Posted: Sat Feb 24, 2024 6:08 pm
by Professor Fate
I once used roofing tar and beer cans to repair rotted wheel wells on my '80 Jeep Cherokee 35+ yrs ago.... a glob will do yah!
Re: Coi Tar
Posted: Sat Feb 24, 2024 7:49 pm
by J1MGolden
There are three or more heat levels, you have to get the highest one.
That one Ron showed you weighs about 80 pounds and costs around $150.
Almost a life time supply though!
