Fix drive shaft ball play, shrink ring
Posted: Sun Mar 03, 2024 4:48 am
Hello T-people
I had a lot of play in my driveshaft ball. I wasn't very impressed with the provider's insert disc and so I've been thinking for a while about how I could solve the problem.
While straightening the rear axle, I had the idea of trying to heat and cool the ring.
It took some patience and several rounds of heating and slow cooling until I had shrunk the ring enough. But it worked well and it fits perfectly. I can even insert a gasket to remove it in the future if it wears out.
I thought maybe this could help someone else too......
greetings from Switzerland
