HELP
Hambick
First Name: Hambick
Last Name: Nercissian
HELP
Post by Hambick » Thu May 30, 2019 12:43 pm
I bought a 27 on a whim, (totally ignorant on it) I'm a 50's guy ... Need help identifying couple of things. please see PICs for Q's
cdromtom
Last Name: McGoldrick
MTFCA Number: 31924
Re: HELP
Post by cdromtom » Thu May 30, 2019 1:13 pm
In picture #2 that is the mixture control for the carb. Allows you to lean it out the mixture or add . It looks like you are missing the choke rod that is attached higher on that rod and goes to the choke lever on the carb. It may be hidden from view in your picture. You would pull the know out to add choke and twist it to change the mixture. I picture #1 normally that lever opens when it is straight up or straight down and closes when left or right.
First Name: David
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Re: HELP
Post by DHort » Thu May 30, 2019 1:30 pm
If not already, join a model T group. MTFCA or MTFCI. It doesnt matter. You will get all kinds of help from them.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Re: HELP
Post by Ruxstel24 » Thu May 30, 2019 1:59 pm
I would do away with the additional shut off valve...
A piece of mechanics wire will do for the choke hook up.
Welcome to the forum from Ohio !!
Hambick
First Name: Hambick
Re: HELP
Post by Hambick » Thu May 30, 2019 5:14 pm
Thank you all for your prompt replies.
BTW, the choke wire is attached, but not visible in the pic.
1- CDROMTOM - Thank you for your detailed, & very informative reply, I feel like I just graduated kindergarten :lol:
2- DHORT - Thank you, I will, was hoping for a geographically closer group, but I'm on it. Soon I hope. :)
3- RUXSTEL24 - Thanx for the advice, choke is already hooked up as suggested. Dunno about extra shut off valve, gotta think about that. Now you wouldn't be from Painesville area, would you? I went to college round there. BTW, thanx for the welcome 8-)
