1912 Length of horn conduit?
Posted: Wed Mar 13, 2024 3:34 pm
by 49willard
I am installing the correct double twist Rubes horn on my new to me foredoor. Can anyone tell me the correct length of the brass conduit not including the horn itself or the squeeze bulb. What I have currently measures 51 inches but to my eye it looks like it droops a little low below the door opening and was there a fastener of any sort holding the conduit loop against the body below the door opening?
New at Model T's, any help much appreciated!
Re: 1912 Length of horn conduit?
Posted: Wed Mar 13, 2024 6:28 pm
by Colin Mavins
It is my under standing that US cars in 1912 the horn tube ran inside the car . my 12 being a Canadian car with a left front door that opens it has a clip , I have only seen this clip on Canadian built cars. AS for lenght Dad renewed this in 1960 and based the lenght on pictures of other cars
Posted: Wed Mar 13, 2024 6:38 pm
by Colin Mavins
It is hard to see but it is there a small brass clip held by 1 flat head screw bottom right corner of the door.
- E5F4005B-5A37-4171-86DC-683C1EDE7F2F.jpeg (84.42 KiB) Viewed 2848 times
Here are 2 pics of original cars both are a little long in my opinion. I would say these cars are US cars as they have no hinges on the left door . They do not have the Canadian clip
Posted: Wed Mar 13, 2024 8:11 pm
by michaelb2296
39”is what i measure this rubes as…. Not sure if its the same as yours. Minus the 3.25” brass end that screws into horn and minus the bulb mount bracket. I.e. just the distance of the “exposed” tube. So, maybe 1/2” more…
Does that help?
Posted: Wed Mar 13, 2024 8:21 pm
by Russ T Fender
Can't say it's right but this is how it is on my late '12. Can't measure the length as I'm not near the car now.
Posted: Wed Mar 13, 2024 11:51 pm
by BubbaSmithTinLizzy
According to this 1913 advertisement the standard flexible tube length was 40"
Posted: Thu Mar 14, 2024 6:32 am
by 49willard
Colin, Michael, Russ and Bubba thank you for your responses! Colin, the picture of your car just looks right to me. I agree that the other era pictures look too long. I suspect that without the clip the tubing could lay over the door opening. Michael, thanks for the 39" measurement. That agrees with the 40" in the era ad provided by Bubba. It is interesting Russ however that your tubing is long more like the era photos. I think that I will mock up the horn/tubing with 40 inches before cutting and could consider a clip. I do have twin sidemounts on the (US) drivers side. The other help provided by the pictures is the placement of the horn as to height as mounted on the firewall. Thanks to all!
Bill
Posted: Thu Mar 14, 2024 7:53 am
by Joe Bell
My original 12 shows the horn on the inside, firewall is drilled and the mounting holes on door are on inside, never been restored.
Posted: Thu Mar 14, 2024 9:32 am
by Russ T Fender
For what It's worth, my car was restored from a compete original car and that is the way the horn and cable were set up when the car was found. I assume someone secured it along the wood runner at some point to keep it from slapping on the door as I doubt that is correct.
Posted: Thu Mar 14, 2024 12:15 pm
by 49willard
Joe,
Is your 12 a Fore-door? If so where was the bulb for the horn located? Mine came to me with a single twist, hole thru the firewall with the bulb up on the top of the "door". This meant that the left side "door" panel and A pillar could not removed with the horn connected. I purchased a double twist horn which is not designed to go thru the firewall (I think?) and was planning to mount the bulb outside? Did I mention that I am new to the T community! I did not see how with the horn thru the firewall would allow the doors to be installed with the bulb on the mounted outside by the drivers left arm. What am I missing?
Posted: Thu Mar 14, 2024 6:55 pm
by Colin Mavins
Just to through a monkey wench into the mix here are some US 1912s with the single twist black and brass tube inside the body
- 1B092E49-781B-4E7D-96B4-708D39AF8543.jpeg (89.06 KiB) Viewed 2640 times
- IMG_7984.jpeg (60.15 KiB) Viewed 2640 times
Posted: Thu Mar 14, 2024 9:31 pm
by 49willard
Colin Mavins wrote: ↑Thu Mar 14, 2024 6:55 pm
Just to through a monkey wench into the mix here are some US 1912s with the single twist black and brass tube inside the bodys-l1600 (38).jpg1B092E49-781B-4E7D-96B4-708D39AF8543.jpegIMG_7984.jpeg
I agree that the horns appear to go thru the firewall in the photos but I do not see a squeeze bulb. Is it a case where the squeeze bulb is direct connected to the horn without any flexible hose such that you would reach down and forward to squeeze the bulb?
Posted: Fri Mar 15, 2024 4:17 pm
by Colin Mavins
In two of the pictures the bulb comes up in the centre of the door
Posted: Fri Mar 15, 2024 4:36 pm
by Colin Mavins
Posted: Fri Mar 15, 2024 4:39 pm
by 49willard
Colin Mavins wrote: ↑Fri Mar 15, 2024 4:17 pm
Colin, thanks for the original pix, that is helpfull!
I do now see the bulbs however it would seem that door removal is not an option.
Posted: Fri Mar 15, 2024 5:14 pm
by Colin Mavins
I dont think door removal was a big thing back in the day US cars dont have a driver door because it is so hard to get in and out of, I have not used the driver door on my T since I was 18 years old Canadian cars have left front doors because Canadian plants built right hand drive cars. I have pictures of my car back to 1936 I think you will find the only time my doors have been off is then you pull the engine. On another note if you would like side curtain patterns I can email them to you Cheers Colin
Posted: Sat Mar 16, 2024 8:21 am
by 49willard
Colin,
Thanks for your response and offer of patterns. I would like to take you up on your offer of the patterns. I suspect that I will most likely run with the doors removed but for a fall tour doors and further enclosing the cockpit sounds like a fine idea. I will try to figure out how to send my contact info offline.
