Anyone have an extrra ignition switch assembly?
Posted: Thu May 30, 2019 7:05 pm
by Dave_Kriegel
I need one quick to get a car ready for my Grandson to learn to drive in, All the suppliers are out of reproductions I have sent mine in for rebuild but if anyone has one for sale it will be appreciated I have posted also to classified with no takers
Re: Anyone have an extrra ignition switch assembly?
Posted: Fri May 31, 2019 10:04 am
by fxlew
Why wouldn't you just wire in some toggle switches until your switch assembly is returned? It is very easy to do.
Posted: Fri May 31, 2019 10:56 am
by Rick_Rice
Hi David,
I have a proper new reproduction ignition switch for you that I bought off of Lang's last year if you are in a bind. I also have the new bezel ring that is required for the reproduction ignition switch, as well as the improved lighted amp gauge that includes a needle that won't bounce. Feel free to call me on my cell to discuss.
Kind Regards,
Rick Rice....Cell (330)714-8151
Posted: Fri May 31, 2019 11:01 am
by Original Smith
Why not try the classifieds, or ebay.
Posted: Fri May 31, 2019 12:38 pm
by Dave_Kriegel
Hi I have tried the classifieds I am bidding on the only available switch on ebay
Posted: Fri May 31, 2019 12:44 pm
by John kuehn
Have you tried Fordbarn? They have classifieds for T parts.
Posted: Fri May 31, 2019 1:46 pm
by Rick_Rice
Well,
I guess you don't want the ignition switch assembly very bad. I have been sitting next to my cell phone all morning long and you never called. Please read the thread, see my response to help you and call if you are in need.
Kind Regards,
Rick Rice
Cell (330)714-8151
Posted: Fri May 31, 2019 2:03 pm
by Steve Jelf
If you already have a switch coming, I second the idea of a toggle switch from the local auto parts store while you wait. I believe they're around $5. You want a three-position switch: OFF, BAT, and MAG. If you intend to use the lights just add another: OFF, BRIGHT, and DIM, and an OFF-ON toggle for the tail light
Posted: Fri May 31, 2019 2:19 pm
by Mark Gregush
I wouldn't even bother with hooking up the mag, just off/on battery supply. By the way I sent an Email with another Ebay listing. If you want head and tail light, I would just add another off/on switch, hook the tail light and dim side to one terminal and power to the other.
For now I would just run a jumper to ground on the generator so it does not burn out if you chose to go that route.
