Odd T differential spider
Posted: Fri Mar 15, 2024 1:12 pm
by Kenny Edmondson
What is this T style differential spider for? No center hole for the axles…
Re: Odd T differential spider
Posted: Fri Mar 15, 2024 1:22 pm
by RVA23T
Man I wish it was April 1 so I could say
"Japanese export differential with extra Ninja throwing star included."
Posted: Fri Mar 15, 2024 1:28 pm
by speedytinc
Fonzie says AAAAAAAAAAAAAA
Posted: Fri Mar 15, 2024 1:44 pm
by Dan McEachern
Perhaps a really early spyder? Kim Dobbins may know. Any chance it has DB on it. I know the really early spyder gears had bronze bushings in them.
Posted: Fri Mar 15, 2024 3:18 pm
by Kenny Edmondson
Well it is a Model A spider. Never would have guessed that. Same exact size as a T only no hole… Thanks John.
Posted: Fri Mar 15, 2024 4:11 pm
by RVA23T
so the A axles are retained by the carrier correct?
Posted: Fri Mar 15, 2024 8:19 pm
by Mark Gregush
And Model A spider gears are the same as T. Later they did add an oil hole, but fit and function, the same. Take some time to go through the 1928 Model T parts book, you will find a few parts that carry the A part numbers.
