Welded rods with an A crank
Posted: Fri Mar 29, 2024 10:05 pm
by Bruce Compton
I have a very nice 1913 Canadian block (three digit Canadian number) that has had a Model A crank installed. It also has a reground cam, adjustable and later valves and new 0.060 pistons and rings. Looking close at the connecting rods , it appears that someone welded T tops to A bottoms, The rods and crank are beautiful and the engine has run maybe 2-3000 miles and shows very little wear. The weld is right below the wrist pin hole and does not show any signs of fatigue, but I'm wondering if this is accepted and safe practice. BTW, the Main caps are the ones in Lang's catalog. A T buddy that has owned over 100 Model T's says it was a common thing to do, but I'm wondering why someone would not just modify the top of a stock A rod (bronze bushing with retaining clips)?? I believe that A rods and T rods are both 7" C-C. Any comments???? Thanks in advance. Bruce
Re: Welded rods with an A crank
Posted: Fri Mar 29, 2024 10:51 pm
by 1915ford
Was on a tour years back where a rod broke and grenaded a guys block. Tour over. T rods welded to a rods same as what you are describing. Even before seeing that i just think that trusting a welded rod is not something i would want to try with a block i care about. Especially if you don't know who, or how the welding was performed.
Posted: Sat Mar 30, 2024 12:31 am
by Kevin Pharis
Welded rods are a quite common reality of A crank motors in the pre SCAT crank world. The A rods are 7.500” center distance and require a special piston if not shortened. The special A rod pistons are notorious for pumping oil, and the T tops allow standard piston choices. I’ve made up several sets of shortened A and hybrid T/A rods, and choose to box the rods for additional strength. Welding near the wrist pin is typical
Posted: Sat Mar 30, 2024 11:30 am
by Les Schubert
Related but not, there were cast aluminum rods available for the A crank in a T block. I actually own a new set and a set of the bearing shells.
Sorry for the diversion!
Posted: Sat Mar 30, 2024 12:25 pm
by Bruce Compton
Les, are they for sale? Bruce
Posted: Sat Mar 30, 2024 12:38 pm
by Dan Hatch
Buick 3800 V6 pistons will work. Need special bushings for A rods.
Posted: Sat Mar 30, 2024 1:45 pm
by Brian Cress
Dan, are the Buick 3800 pistons "deck height" at TDC, or do they rise above the block like a stock T or A piston?
Posted: Sat Mar 30, 2024 2:19 pm
by Dan Hatch
Flat top pistons.
Posted: Sat Mar 30, 2024 3:19 pm
by Brian Cress
Thank you for clarification.
Posted: Sat Mar 30, 2024 3:23 pm
by AndyClary
So the Buick pistons work but you have no compression?
Andy
Posted: Mon Apr 01, 2024 9:28 am
by Kenny Edmondson
The Buick pistons work great. There’s a little protrusion above the deck.
Posted: Mon Apr 01, 2024 12:49 pm
by Brian Cress
Thanks for the picture Kenny.
