Exhaust Nut Thread Size
Posted: Fri Apr 05, 2024 3:57 pm
by jagiven
Hello, I need to clean up the threads on a 25 exhaust manifold. What is the thread size?
Re: Exhaust Nut Thread Size
Posted: Fri Apr 05, 2024 4:13 pm
by ThreePedalTapDancer
1 7/8-16 thread size
Posted: Fri Apr 05, 2024 4:30 pm
by jagiven
Humm, That is the size die I purchased. I would guess it is a 1/4" to small. It is an OUS made thing, I did not measure it to confirm the size, but it is stamped with the correct info.
Edit: I just looked on the website I ordered it from. I ordered a 1-7/16 x16. I guess I need to return it and get the correct one.
Thanks for helping
Posted: Sun Apr 07, 2024 9:56 am
by vping
Where are you ordering the die from? A quick Google search list prices around $100. Is this a rare exhaust manifold you are trying to re-thread?
Posted: Sun Apr 07, 2024 2:14 pm
by jagiven
It's to clean up the threads. I found one on Zoro, for about $80, never hear of them before.
Posted: Sun Apr 07, 2024 2:24 pm
Unless this is a special aftermarket manifold, it's one of nearly two million made by Ford in 1925. The same manifold was made in other peak production years. I expect a good manifold would cost a lot less than a giant die.
Posted: Sun Apr 07, 2024 3:46 pm
by jagiven
Good to know. This one is nice and flat. Everythng looks good, but the threads look like crap.
Posted: Sun Apr 07, 2024 4:19 pm
"Flat" is a misnomer in T language ! One needs to verify the "droop" in the manifold by holding a straight edge at the BOTTOM of #'s 1 & 4 to see just where #'s 2 & 3 are - most the time the center ports will be way off !
Posted: Sun Apr 07, 2024 4:46 pm
by jagiven
Thanks, the center two on those one has about an 1/8" droop.
Posted: Sun Apr 07, 2024 5:24 pm
Then dont waste your money on a die until you straighten it.
Or put you money into a new one.
Posted: Sun Apr 07, 2024 5:53 pm
jagiven wrote: ↑Sun Apr 07, 2024 2:14 pm
$17.60 -
https://www.ebay.com/itm/126307511183?i ... R7rT3ajXYw
Posted: Sun Apr 07, 2024 6:56 pm
by Ron Patterson
Jerry
That is a great eBay price on the 1 7/8 X 16 Die.
But check cost of the Stock before buying.
Ron Patterson
Posted: Sun Apr 07, 2024 9:02 pm
Posted: Mon Apr 08, 2024 8:39 am
by jagiven
Thanks Steve for the detailed write-up on your page. Also hope your recovering well.
