Ruckstell 13 tooth pinion gear
Posted: Fri Apr 05, 2024 8:09 pm
So I just got a 13 tooth pinion stamped with Ruckstell, 8501 13-40 20N on the front and LC.CO. ID24 along with another number that can't be read on the back.
Would this have been used with the standard 40 tooth ring gear or other? With 40 tooth, looks to be about 3.07 to 1. How common was this combination, I don't see a lot in the Ruckstell repair book from the club.
