Coil rebuil capacitor fit question
Posted: Sun Apr 07, 2024 3:32 pm
by Jim11787
I decided to try and rebuild a few coils. The new capacitors I received from Langs are cylindrical and do not fit in with the glass plate. Do I remove the glass plate with this newer style cap?
Re: Coil rebuil capacitor fit question
Posted: Sun Apr 07, 2024 3:41 pm
by NealW
I did when I used the round capacitors to rebuild coils.
Posted: Sun Apr 07, 2024 4:07 pm
by Jim11787
NealW wrote: ↑Sun Apr 07, 2024 3:41 pm
Posted: Sun Apr 07, 2024 4:11 pm
by Ron Patterson
This assumes you have the 418P47494 type capacitors and a Ford manufactured coil.
There are two ways to install them: one is to remove the glass separator to make room for the cacpacitor OR; if you prefer, remove the glass separator AND the two wooden blocks between the glass separator and the secondary winding, after installing the capacitor reinstall the glass sedparator in the area previously occupied by the wood blocks.
Regardless which way you go, always repot the coil with tar to firmly hold the new internal parts/wiring from moving.
Posted: Sun Apr 07, 2024 4:35 pm
by Jim11787
Ron Patterson wrote: ↑Sun Apr 07, 2024 4:11 pm
Coil Resistance Readings 001.jpgThis assumes you have the 418P47494 type capacitors and a Ford manufactured coil.
Thank you Ron! Much appreciated.
Posted: Mon Apr 08, 2024 6:13 am
by Chris Barker
I have found that it is easiest to carefully remove the left side of the coil to gain access and remove the old glass and capacitor.
Posted: Mon Apr 08, 2024 7:31 am
by Moxie26
And after your connections are checked , and the side is replaced, hot tar will keep everything in position including the wood side you replaced , no glue needed on the wood.
Posted: Mon Apr 08, 2024 10:41 am
by Les Schubert
I have been running coils that I installed ignition “condensers” from’60’s era design Ford cars for at least 40 years. I removed the glass to get room and never “repotted” with tar ( some RTV yes). They work great and I have had them recently tested and they test great.
Just saying!
Posted: Sun Apr 14, 2024 3:11 pm
by J1MGOLDEN
Rebuilding those coils is what the British call penny wise and pound foolish!
Been there and done that!
This #3 tar barrel cost $95 about 25 years ago, I hate to ask the price now.
- TarBarrel Small.JPG (18.17 KiB) Viewed 2460 times
Posted: Sun Apr 14, 2024 4:21 pm
by Art M
Why aren't the oval style no longer made. Is there something inherently wrong with them.
Art Mirtes
Posted: Mon Apr 15, 2024 4:49 pm
by Moxie26
Hi Art ..... I'm not sure who made those capacitors, or even if they're still in business that I noticed also that they're not available. The ones that I installed in coil rebuilds as far as I know or still working because I haven't had any complaints.
