Brass plugs in car. Passageways
Posted: Thu Apr 11, 2024 10:34 pm
by NY John T
Hi all,
What suggestions do you all have for replacing the small brass plugs that seal the carb passageways? They're made of brass originally, I believe. Can I use heavy copper copper wire, or does it have to be brass? Thanks for your help.
John
Re: Brass plugs in car. Passageways
Posted: Thu Apr 11, 2024 10:49 pm
NY John T wrote: ↑Thu Apr 11, 2024 10:34 pm
Hi all,
John
Stan Howe suggested using
set screws for the next time
https://www.mtfca.com/discus/messages/1 ... 1279536155
Posted: Fri Apr 12, 2024 6:33 am
by Dan Hatch
Just be sure you don’t thread the screw in so far as to block the passage way.
Posted: Fri Apr 12, 2024 7:55 am
by Mark Nunn
I had brass screws on a shelf that worked.
Posted: Fri Apr 12, 2024 8:33 am
by jab35
Copper wire of appropriate gage would be fine, many use brass filler rod. I've used brass rod 'tinned' with solder to insure a tighter fit.
Posted: Fri Apr 12, 2024 9:46 am
I've had no trouble using Uncle Stan's method.
