Bolt for AC brakes
RGould1910
Last Name: Gould
Bolt for AC brakes
Post by RGould1910 » Thu Apr 18, 2024 5:36 pm
I'm ready to install an original set of AC brakes. The instructions tell me to to remove the lower bolts holding the radius rods to the backing plates and substitue the longer ones that are included. I dont have the long ones and need to buy them. I assume they are the same diameter and tpi as the radius rod bolts but would like know the length I need. I assme they are held fast with cotter pins so I'll have to drill holes. Do I have it right?
Last Name: Strange
Re: Bolt forbAC brakes
Post by CudaMan » Thu Apr 18, 2024 5:44 pm
If I recall, the bolts that I bought were about 1/2 inch longer than the stock bolts. I did a trial assembly with the castle nuts snugged down, then used a drill through one of the nut castellations to mark where to drill for the cotter pin. I then removed the new bolts and drilled them for the cotter pin on my tabletop drill press. :)
RGould1910
Last Name: Gould
Re: Bolt for AC brakes
Post by RGould1910 » Fri Apr 19, 2024 12:43 am
Thanks Mark
