Piston Wear
Posted: Sun Jun 02, 2019 1:19 pm
I have my 1926 TuDor engine out for a generally inspection. It has about 20K miles on it since the last major rebuild. Here are a couple pictures of the pistons. They are 1 to 4 left to right.
Next the piston pins show some slight sticking as the rod end moves back and forth. I was considering removing the pins and polishing them so that they move freely.
Then one last question. How would I know whether or not to replace the piston rings. They do not look bad, are free in the slots. The last compression check I made on the engine earlier this year showed even 55# per cylinder.
Thanks Mike
You can see that the wear pattern is generally down the center of the pistons. #1 is well cenetered, but #2,3,4 on the split side show wear more on the left of center side. Then on the non split side, only #3 show off center wear. Could this wear be the result of slightly bent rods? Next the piston pins show some slight sticking as the rod end moves back and forth. I was considering removing the pins and polishing them so that they move freely.
Thanks Mike
