seeking picture of correct 1911 Torpedo fuel line routing
Posted: Sun Jun 02, 2019 8:59 pm
I have never seen a diagram or picture of the correct routing. An early post by John Ragan hints at the oddity and discusses the unique shut off valve as well. I would be ever so grateful if someone with a Torpedo could provide a sketch, picture or good verbal description of the line, it's routing, and rotational position of the sediment bulb (I believe the outlet is NOT directly foreward).
I have copies of pictures/diagrams for touring, sedan, coupe, runabout. None of these are correct for a Torpedo.
Thank you in advance for any info you can provide.
