Period correct shocks
Posted: Thu Apr 25, 2024 6:39 pm
by Will
What rear period correct shocks will work with AC brakes?
Re: Period correct shocks
Posted: Thu Apr 25, 2024 8:28 pm
by ModelTWoods
Don't have your answer, but I know that there are some prone to breakage that should be avoided.
Posted: Thu Apr 25, 2024 9:33 pm
The issue with almost all aftermarket rear shocks have with accessory brakes (AC, RM etc) is that their perch doesn't clear the additional thickness of the drum. Snubbers are a possibility as are friction shocks OR have a rear perch made to clear.
I was fortunate to have some made for Hassler shocks as my project unfolded I wasn't sure if I was going to use them. Someone was looking for them and the "professional" maker wasn't ready to make another set, so I sold mine
but the idea should work for others
Posted: Fri Apr 26, 2024 10:48 am
Will wrote: ↑Thu Apr 25, 2024 6:39 pm
Have seen Hassler Pan Cake rear shocks clear a set of small drum outside brake, as there is some space above the brake drum.
Would think AC brakes over the factory small drums would be ok with Hassler Shocks.
- hass size.jpg (97.84 KiB) Viewed 1651 times
Regular Hassler 'Bee Hive"
- IMG_0088 (600x450) (595x446) (2).jpg (142.48 KiB) Viewed 1651 times
1924 and later 'Pan Cake' Hassler
Posted: Fri Apr 26, 2024 10:59 am
by Craig Leach
Hi Will,
Speedway Motors sells a single arm Truffault-Hartford style friction shock # 5606021 & some Model A style dog bone connectors & balls.
They can be attached to the rear crossmember & either to the shackle or axle putting them out of the way. Examples of these can be
scene on some speedsters on line. See NWVS thumb nail gallery pics. I have seen these on several touring cars also.
Craig.
Posted: Fri Apr 26, 2024 9:08 pm
by Russ T Fender
I run Gabriel snubbers on my '22 Centerdoor.
Posted: Sat Apr 27, 2024 5:40 am
by haydonr
I don't know much about them, but was given these Hartford branded units, and assume they fit a T?
What I thought looked promising was that they don't sit over top of the drum like the Hasslers do in the top of the picture (or as per Dan's pictures) which I always thought would interfere with the AC bands.
Posted: Mon May 13, 2024 9:36 am
by warwick_preval
Hello Dan i wonder if you could post a photo from the front view of that AC brakes & the Hasslers set up in your photos please as i would like to run some thing similar cheers Warwick.
