Coil hardware question
Posted: Fri Apr 26, 2024 9:48 am
by Jim11787
When replacing the coil top hardware can someone tell me where the 2 fiber washers go in the assembly process? The old coil I disassembled did not have them. I assume they are insulating washers.
Re: Coil hardware question
Posted: Fri Apr 26, 2024 12:38 pm
by Moxie26
Are you referring to the metal top coil, or the wood top coil?
Posted: Fri Apr 26, 2024 3:13 pm
by Mark Gregush
The two fiber washers are used under and over the bridge at the adjustment screw. I generally only use one under it.
Posted: Fri Apr 26, 2024 4:12 pm
by Jim11787
Thanks Mark. That’s what I thought.
Posted: Sat Apr 27, 2024 11:43 am
by Ron Patterson
This Ford diagram depicts the details for what and where point mouning hardware should be installed on the Williams KW Ford ignition coil.
Posted: Sat Apr 27, 2024 11:44 am
by Ron Patterson
Coil Sketch SK-2202.pdf
(1.24 MiB) Downloaded 183 times
Posted: Sat Apr 27, 2024 1:12 pm
by Jim11787
Thank you Ron.
Posted: Sat Apr 27, 2024 1:20 pm
by Chris Barker
I agree with Mark; I find that the coil is best set up with just the fibre washer under the contact plate, above the coil spring.
And then TWO nuts above, locked.
Posted: Sat Apr 27, 2024 2:13 pm
by Ron Patterson
I got this sketch out of JPG format so it is easier to print.
