Rocky Mountain Brakes - where to buy?
Michael_Velling
First Name: Michael
Last Name: Velling
MTFCA Number: 29246
Board Member Since: 2010
Post by Michael_Velling » Tue Jun 04, 2019 8:06 am
Hello,
i am planing to buy Rocky Mountain brakes for my 1925 Runabout. Where is it the best way to buy? Are the systems all the same?
Thanks a lot
Greetings from Germany
Michael Velling
Visit our Model T website: www.velling.de
MTFCA Number: 4838
MTFCI Number: 115
Re: Rocky Mountain Brakes - where to buy?
Post by DanTreace » Tue Jun 04, 2019 8:41 am
The R-M brakes are the version with the large drum added to the rear wheel, so very good surface area for stops.
For your small drum axle get the set with the large outer drum, your normal small drum is retained but sandwiched inside the new RM drum.
Obtain from suppliers like Lang’s, which may have them in stock, or direct from the mfg. at a savings, while shipping may delay from the mfg, as these are made on order and the mfg. might be slower on international shipment.
TonyB
First Name: Tony
Last Name: Bowker
MTFCA Number: 32
Post by TonyB » Tue Jun 04, 2019 10:17 am
The Rocky Mountain Brake’s made in RMB Company in Temecula are NOT made to order, they are made in quite large (~100) batches. I was there one time when a large box of drums were delivered. Most times are in stock and ready for shipment.
Tony Bowker
Ramona, California
1909 Touring, 1914 Touring, 1915 Speedster, 1924 Coupe.
Michael_Velling
First Name: Michael
Last Name: Velling
MTFCA Number: 29246
Post by Michael_Velling » Wed Jun 05, 2019 8:08 am
Thanks a lot for the fast Information. Will measure the Diameter of my drums and then order at Langs.
Michael Velling
John.Zibell
Last Name: Zibell
MTFCA Number: 30265
MTFCI Number: 24046
Post by John.Zibell » Wed Jun 05, 2019 8:40 am
For not much more you could get hydraulic brakes. These also work well in backing and in the wet. If these were available when I restored my T it is what I would have purchased. http://www.texastparts.com/mm5/merchant ... ode=Safety
1926 Tudor
