Hand Brake / Brake Lever Differences...
Posted: Wed May 15, 2024 9:05 am
by BRENT in 10-uh-C
I am looking for a Hand Brake Lever suitable for a '09/10 that is nice enough that I can have brass-plated. Bruce doesn't mention much about the structural differences between the years, and I didn't see anything in the Judging Guidelines either, -so is there any differences in the shapes of the lever (-not the cross-shaft or cam) that I should be looking for to look aesthetically correct??
TIA
Re: Hand Brake / Brake Lever Differences...
Posted: Wed May 15, 2024 10:45 am
TIA
Past discussion with detailed pictures
https://www.mtfca.com/discus/messages/7 ... 1505093903
Posted: Wed May 15, 2024 1:02 pm
by BRENT in 10-uh-C
Thank you!
Posted: Wed May 15, 2024 1:07 pm
I have two late ones. On one, the lever is straight, and on the other it is bent in toward the door.
Posted: Wed May 15, 2024 10:03 pm
One addition to my observations in the link Frank supplied. The flat headed clevis pins were also brass plated. I found traces of the plating on the pins of the assembly I discovered.
