What are these gears?
Posted: Fri May 17, 2024 8:25 pm
by KWTownsend
Re: What are these gears?
Posted: Fri May 17, 2024 8:38 pm
by JTT3
Sort of resembles the gears in a plunger horn.
Posted: Fri May 17, 2024 8:42 pm
by Moxie26
Guessing on the size of the gears compared to the metal washer. Could they be speedometer gear that's mounted on the front wheel bracket that mates with larger steel gear mounted on wheel hub ? .... Metal or fiber ?
Posted: Fri May 17, 2024 9:00 pm
by KWTownsend
Metal 1/2" thick, 1-1/4" dia.
Posted: Sat May 18, 2024 11:18 am
by flatbroke3
oil pump gears
Posted: Sat May 18, 2024 12:15 pm
Steering gears?
Posted: Sat May 18, 2024 1:47 pm
by jab35
I'm with Harold. On gear in each pair has a keyway
Posted: Sat May 18, 2024 4:38 pm
by KWTownsend
For Model A?
