Correct oil for Muncie transmission
Posted: Wed May 22, 2024 2:43 pm
by Reno Speedster
What oil should I be using in my Muncie auxiliary transmission?
Re: Correct oil for Muncie transmission
Posted: Wed May 22, 2024 3:22 pm
by Dennis Prince
I use 140w gl-4, not sure if that is what it calls for but it has worked well for many years.
Posted: Wed May 22, 2024 3:27 pm
by Craig Leach
I run 85-140 & Ed AKA #4 the 600W Ed has way more miles than I ever will.
Craig.
Posted: Wed May 22, 2024 9:15 pm
by Dan McEachern
Redline Oil makes a synthetic heavy duty gear lube called Shock Proof. It has worked extremely well in my Chicago transmission. It runs cooler and is much quieter since I changed it over from conventional gear oil.
