Crank Pulley
Posted: Fri May 31, 2024 8:36 pm
by GG Gregory
Ok, I should know this but I’ve forgotten. Is the pin that holds the crank pulley a tapered one? I don’t think it is but I’m having a time getting it out. I’d rather not pound on it really hard but it’s looking like I make have to.
Re: Crank Pulley
Posted: Fri May 31, 2024 8:45 pm
It shouldn't be a tapered pin, unless someone modified it in the past.
What type of pulley do you have? Stock, Ford style, or modern aluminum one?
Re: Crank Pulley
Posted: Fri May 31, 2024 9:06 pm
by GG Gregory
It’s a stock Ford pulley.
Re: Crank Pulley
Posted: Sat Jun 01, 2024 8:15 am
Is the pin positioned vertically, so that it can pass through the clearance hole in the nose of the pan?
Re: Crank Pulley
Posted: Sat Jun 01, 2024 10:55 am
You removed all the old cotter pin?
You know the pulley has a small & a large hole. The pin goes out & in thru the large hole.
Check for evidence of a setscrew thru the front of the crank.
Could be locktite was used amongst many other possible ways to tighten a loose pin.
Re: Crank Pulley
Posted: Sat Jun 01, 2024 12:04 pm
by Craig Leach
Hi GG,
I had this happen to me a while back, not wanting to beat the Babbitt out of the engine to remove the pin I machined a pin & adapter to go
on my H.F. ball joint press to push the pin out. Keep in mind this will deform the pulley requiring it to be replaced. Before that I would turn
the pin straight up & down, put a socket or pipe that fits through the hole in the pan on a jack to support the crankshaft while driving down
on the pin. Both methods are also handy for installing the new pin. But will run the risk of deforming the pulley if at is too tight.
Craig.
Re: Crank Pulley
Posted: Sat Jun 01, 2024 1:10 pm
by GG Gregory
Thanks. Yes I have the cotter pin out. I’ll rig up something to help press it out, not worried about the old pulley.
