Rear axle question
Posted: Mon Jun 03, 2024 1:08 am
by DHort
If you are installing the old axle seal you will use the steel washer outbound of the hyatt bearing.
- 474627s.jpg (2.23 KiB) Viewed 878 times
If you are using the modern axle seal with o rings, do you still install the steel washer?
- 101s.jpg (2.68 KiB) Viewed 878 times
Re: Rear axle question
Posted: Mon Jun 03, 2024 2:47 am
by JohnH
No, the steel washer is not used. It keeps the bearing and felt in position for the original type seal. The modern seal keeps the bearing in position by itself.
