Brake band adjustment
Posted: Thu Jun 06, 2019 5:42 pm
by Allen Banks
Novice question, but how do you tighten up the nut and have the washer follow so the notches line up? I tighten the nut but the washer stays put. ???
Re: Brake band adjustment
Posted: Thu Jun 06, 2019 5:51 pm
Yes, the washer is notched and stays in the pedal shaft slot.
Posted: Thu Jun 06, 2019 5:52 pm
Also - you will "feel" when the notch in the nut engages the washer protrusion - they're 180 degrees apart.
Posted: Thu Jun 06, 2019 6:00 pm
by Ruxstel24
What Steve said, in other words, you can only adjust the brake and reverse half a turn at a time.
Posted: Thu Jun 06, 2019 6:25 pm
by Allen Banks
Got it! Thanks guys!
