Front hub archeology
Posted: Wed Jun 19, 2024 1:29 pm
So, in going over the mechanicals, took the front hubs apart to check the bearings.
Both hubs are running on ball. 80% of the balls have flat spots, but no scarring or pitting.
The races actually appear to be in decent shape, again, smooth face, but where the larger inner races do show a slight run in groove.
I decided to get the new NOS inner hub races and outer spindle cones from Lang's before they're long gone, along with some new balls and I figure she'll be good to go for the rest of her limited drive/parade life. The only unobtanium being the outer hub race and inner spindle race..but...appears they're in good shape. Certainly way cheaper than the current options for rollers.
The obvious though is, like most everything else on a T, is the history of replacement parts over time.
While Daisy is a March1914 build, the left hub is a 1910-13 variant. Also, cast with a "GHC" Logo... CH? I tried doing a search but came up empty....anyone confirm? Possibly a Cleveland Hardware?? The right hub being a later "Ford" marked hub.
