mystery wire
Posted: Sat Jun 22, 2024 7:49 pm
by ecory0
I pulled off my starter this evening and SURPRISE, this wire said hello to me.
Any idea what it is? I will be taking the hogs head off tomorrow to get a better look. The other surprise was the broken bolt (bottom right). Got it out pretty easy though.
Re: mystery wire
Posted: Sat Jun 22, 2024 9:22 pm
by got10carz
The last one I found went to the Flux Capacitor. Made time travel very fast!!
Re: mystery wire
Posted: Sat Jun 22, 2024 9:30 pm
by ecory0
Lol, maybe I'll go back in time and find whoever put that wire in there.
Re: mystery wire
Posted: Sat Jun 22, 2024 11:02 pm
by mtntee20
Is that a Braun speed sensor? As in Tachometer maybe? That might be a ground wire from one of the lower Bendix cover bolts. The wire would have to be out of the way for the Bendix engagement.
Re: mystery wire
Posted: Sun Jun 23, 2024 6:47 am
by ecory0
I don’t have a speed sensor. Maybe in its past it had one and it was left there? Where would the wire lead to?
Re: mystery wire
Posted: Sun Jun 23, 2024 7:29 am
by BHarper
Hi Eli,
On my car that red wire is for the magneto.
Good luck with your project.
Re: mystery wire
Posted: Sun Jun 23, 2024 8:30 am
by ecory0
I should have circled the wire I was referring to. Its inside, the blue one.
Re: mystery wire
Posted: Sun Jun 23, 2024 9:10 am
by TWrenn
Whatever it is that's just plain crazy and get it out of there!!
I love the flashlight! Tell us where we can get one like that pls.
Re: mystery wire
Posted: Sun Jun 23, 2024 10:33 am
by ecory0
the light is from Harbor Freight. You can find them on sale for about $22.
This one is similar. I couldn't find the kind I have but they are in the stores.
https://www.harborfreight.com/lighting/ ... 59103.html
Re: mystery wire
Posted: Sun Jun 23, 2024 11:36 am
by mtntee20
Eli, What is that mounted to the oil pan, just below the hole for the starter? It says BRAUN on it and is NOT original. I suspect it's some kind of speed sensor for rpm of the magneto/flywheel. Otherwise, there is NO electric wiring in the hog's head area other than the magneto to post.
Could it be a temperature sender of some kind?
Re: mystery wire
Posted: Sun Jun 23, 2024 1:31 pm
Pretty sure that's the "light bar" that was referred to above.
Re: mystery wire
Posted: Sun Jun 23, 2024 1:39 pm
by ecory0
The Bruan is a magnetic light.
As far as the blue wire, no clue. It wasn't connected to anything, just a hitchhiker.
If you didn't see my other post, I jacked up the magneto when removing the bell cover. Ugh....
Re: mystery wire
Posted: Sun Jun 23, 2024 2:09 pm
by Dan Hatch
Just we are all on the same page, you removed the “Hogs Head”.
That is what the transmission cover has been called since Edsel wore short pants.
Re: mystery wire
Posted: Sun Jun 23, 2024 2:33 pm
mtntee20 wrote: ↑Sat Jun 22, 2024 11:02 pm
BRAUN object is the flash light illuminating the hole
