First of all I am kind of a purist. I have a 16 T with a 24 engine so I don't have to crank it. But, I have the 16 engine in the garage and everything is undoable to bring it as close to a true 16 as possible. Having said that I guess I have one foot in both camps.
I am wondering if any of you have installed "The Ideal Timer"? I'm sure you know it's a replacement for the stock timer with electronics.
You can get it with the coil and magneto tester.
I am considering putting this on my 24 engine for recreation.
Please let me know what you think. I value the input I will get from you guys.
Thanks,
Jeff Schroeder
Using modern part replacements
Topic author - Posts: 180
- First Name: Jeff
- Last Name: Schroeder
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring
1916 Touring
- First Name: Thomas
- Last Name: Hicks
- * REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
Re: Using modern part replacements
I have two I timers. I drive a lot. They don't need oil or cleaning. No problems!
- First Name: Rod
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
- Board Member Since: 2014
I highly recommend the I Timer. I put one on my 24 Depot Hack after this summer's Home Coming. The advantage is that it acts exactly as a regular timer, requiring the mechanical adjustment of the advancer on the steering column. It does not ever require cleaning or replacement parts. I did purchase the entire package, including the tester. I am very satisfied with this product. Even though the directions say that it will not start on Mag, my system is 12 volt and it does start on both Mag and Battery.
- Last Name: Hunter
- Board Member Since: 2002
I don't have an "I-Timer", but I do have an "E-Timer" - which in appearance, and in terms of wiring and installation, is the same. The difference is it works on battery only - which suits me because I don't have a magneto.
What I like is that everything looks totally original; the timer built into the housing of a roller timer. No wiring changes were required, and to switch back to a mechanical timer requires nothing but swapping the actual timer over. I don't even have to open the coil box. (For those E-Timer owners who query that, I've set the coils up so the points are still active). I also run it with manual timing adjustment.
The best thing of course is that the timing will always remain perfect with no mechanical contacts to wear and cause a change in characteristic over time. And, ultimately, the perfect timing and lack of contact bounce results in noticeably better driving performance. Smoother across the entire rev range, and particularly at low revs - which means staying in top gear longer.
Highly recommended, and you'll find the product support first rate.
